Axis correction
as i use Repetier FW in a mill and i´m working with a 10Kg load (Mill Motor) on x Axis i have following Problem :
when i move X-axis from 0 to 520mm there is some small bending in my machine.
which is -0.1mm at Position x=0 ; 0 at x=260 and -0.1mm at Position x=520.
this bending is independent of y and z Position and just caused by the weight of x-slider+Motor.
can i use bed correction to compensate this?
as far as i understood bed correction is just for a couple of layers but i Need that as a permanent correction
over the complete z-Range.
any Idea?
BTW , seems to be linear, so starting from x= 0 means to subtract 3.85 microns per mm from Z up to x=260 and from there add 3.85 microns per mm from Z up to x=520.
Ok,
i can´t use z-probing because i need opposite direction of correction
so my question :
how can i generate correction Matrix manually?
- G33 - Measure distortion map
- G33 R0 - delete distortion map
- G33 L0 - List distortion map
- G33 X<xpos> Y<ypos> Z<newdistortioncorrection> - Set new distortion for nearest distortion point.
L0 returns the command to restore current state. Copy this to quickly define your correction and then send the commands.
One more question please as my correction is like a V-shaped line falling linear from 0.1 mm at x=0 to 0mm at x=260mm and rising from there to 0.1 at x=520 (its completely independent from y position) how many points do i have to define?
do you think a 3x3 matrix is enough?
