Raspberry Cam not streaming
                    Hi, I took the opportunity of the new SD mount of repetier-server for raspberry to add a cam to my setup.
                            I selected the pi cam preset in the printer setting and activated the timelapse under the Webcam tab.
All settings seems to be OK and the red indicator of my cam is up, showing that it's all good on that end.
However, I don't get any image in the display area. Only a blank square with a "rec" indicator (see here).
Any ideas where I could have gone wrong and what can be done to fix it?
/usr/local/bin/mjpg_streamer -i "/usr/local/lib/mjpg-streamer/input_raspicam.so" -o "/usr/local/lib/mjpg-streamer/output_http.so -w /usr/local/share/mjpg-streamer/www"
You could also test with different parameters for input_raspicam. E.g. -x 640 -y 480 would be an idea to set a smaller resolution to also reduce traffic.
MJPG Streamer Version.: 2.0
i: fps.............: 5
i: resolution........: 640 x 480
i: camera parameters..............:
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
o: www-folder-path...: /usr/local/share/mjpg-streamer/www/
o: HTTP TCP port.....: 8080
o: username:password.: disabled
o: commands..........: enabled
i: Starting Camera
bind: Address already in use
o: server_thread(): bind(8080) failed
the latest command you gave doesn't pass and adding sudo before doesn't give any feedback. I'm stuck at that point.
https://www.repetier-server.com/setting-webcam-repetier-server-linux/ end of the page
