G32 vs G33
In reading this: https://www.repetier.com/documentation/repetier-firmware/z-probing/ I'm confused when to run G32 vs G33.
I have a COREXY with an inductive probe on zmin and a microswitch set to zmax.
My process:
1. home z (down to the z max micrswitch ~370mm)
2. G32 (4x4 grid)
What I notice is the nozzel doesn't follow the inaccuracies of the bed, it's close, but not ideal. IE origin has a good paper distance, center smashes into the bed.
So as a step 3, should I run G33 or just M323 S1 P1.
Thank you for the clarification!
