Pullups on endstop pins
I'm a bit confused on the pullups on endstop pins. I'm trying out the dev FW so I can use a microswitch to detect out of filament. The filament passes over the switch and when there's no filament, the switch releases therefore the signal goes low or off.
In the fw I've enabled the pullup resistor since that's whats seutp for the other endstops.
so before I uplaod it, I'm curious, what can go wrong if I set this? Do I need to enable the pullup resistor at all?
on the ramps the pause switch is connected on the ramps to the gnd and sig pins on xmax.
Thank you
