"Bad allocation" server becomes unresponsive and must be restarted
edited June 2025 in Repetier-Server
Theres is 10% chance that if I interact thru the web version of repetier server (on the PC its hosted) it'll "crash". prints  in action will continue (but usually crash at a later point wasting time and filament). the web view cannot be interacted and therefor new prints cannot be started. I have 4 printers so again this wastes my time and money. I cant restart the server with active prints as it will guarantee i have to start over and they can not be recovered.
Anyhow this issue has driven me to consider different print farm software. please help, partial log attached
2025-06-27 22:34:20: Time analysing C:\ProgramData\Repetier-Server\printer\Prusa1\jobs/00000159_dragon3 XL_0.2mm_PLA_MK3S_18h1m.g:43862140 us
2025-06-28 02:35:09: bad allocation
2025-06-28 02:35:10: bad allocation
2025-06-28 02:35:11: bad allocation
2025-06-28 02:35:12: bad allocation
2025-06-28 02:35:13: bad allocation
2025-06-28 02:35:14: bad allocation
2025-06-28 02:35:15: bad allocation
2025-06-28 02:35:16: bad allocation
2025-06-28 02:35:17: bad allocation
2025-06-28 02:35:18: bad allocation
2025-06-28 02:35:19: bad allocation
2025-06-28 02:35:20: bad allocation
2025-06-28 02:35:21: bad allocation
2025-06-28 02:35:22: bad allocation
2025-06-28 02:35:23: bad allocation
2025-06-28 02:35:24: bad allocation
2025-06-28 02:35:24: Error in CronJob::fireJob timer30:bad allocation
2025-06-28 02:35:24: Error in CronJob::fireJob timer60:bad allocation
  • "bad allocation" is in first case an issue happening when no memory is available and when that happens software can get instable when it gets no more resources required to work as designed. The error it self is not giving a clue why it happens unfortunately.
    First thing to check is if your version is up to date so it has no known issues. Latest version has no such reports so far so next questions are:
    - If you check it in task manager - is it increasing memory usage over time. Normally it keeps memory usage quite small.
    - Is some other app using the memory so system is just high loaded.
    - If it is server it is likely something rarely used so we got no reports for this so far. Is there something unusual/special? After which action does it start to grow memory? Any custom extensions/gcodes running repeatedly or external software called from within repetier-server during print?
