Picam detected but not selectable
Iam using my Pi 4 2GB with Repetier-Server. I`ve connected a Picam Rev 1.3. The System recognise the Cam but Repetier-Server doesn`t. In the dropdownmenu in the webinterface the cam is listed, but grey, so can`t select it.
I`ve typed in (via ssh)
tail -100 /var/log/syslog
and the output was:
and the output was:
2025-11-07T16:33:48.359962+00:00 RepetierServer MJPG-streamer [16376]: ERROR: could not find input plugin
2025-11-07T16:33:48.360513+00:00 RepetierServer MJPG-streamer [16376]: Perhaps you want to adjust the search path with:
2025-11-07T16:33:48.361211+00:00 RepetierServer MJPG-streamer [16376]: # export LD_LIBRARY_PATH=/path/to/plugin/folder
wich plugin is missing?
What do i have to install?
I am thankfull for any help.
2025-11-07T16:33:53.602217+00:00 RepetierServer MJPG-streamer [16410]: starting application
2025-11-07T16:33:53.603136+00:00 RepetierServer MJPG-streamer [16410]: MJPG Streamer Version.: 2.0
2025-11-07T16:33:53.617483+00:00 RepetierServer MJPG-streamer [16410]: ERROR: could not find input plugin
2025-11-07T16:33:53.618186+00:00 RepetierServer MJPG-streamer [16410]: Perhaps you want to adjust the search path with:
2025-11-07T16:33:53.618803+00:00 RepetierServer MJPG-streamer [16410]: # export LD_LIBRARY_PATH=/path/to/plugin/folder
2025-11-07T16:33:53.619369+00:00 RepetierServer MJPG-streamer [16410]: dlopen: /lib/arm-linux-gnueabihf/libcamera.so.0.3: undefined symbol: _ZN7libpisp22compute_optimal_strideER24pisp_image_format_config
and so on...wich plugin is missing?
