Floor safety margin: DELTA_FLOOR_SAFETY_MARGIN_MM
hey guys,
i'm trying to calibrate my delta printer.. (geeetech g2s pro, with updated hotends)
and am slowly getting there i think. but i'm not sure on one measurement.. namely the floow safety margin.
i understand what it is for but what i don't understand is what to measure exactly.
my understanding was.. from a) slider joint center point to b) top hotbed, when @) height 0.00.
but this gives me a measurement in the 200 plus.
which is compared to the other examples found online is extreme large. (between 4-10x as large)
hope some one can explain how to measure this size exactly.
would really appreciate that.
also is there o good tutorial online somewhere on how to calibrate for the repetier firmware?
although the website config tool is great. it isn't always very clear for the uninformed.
Kind regards
Matthieu
Kind regards
Matthieu
it is still rather unclear how to measure it though.
Repetier said:
1) Z_probe_bed_distance: [mm] = Max. distance to go back for next test.
i really don't understand what is requested here... specially if you take in account also question 2:
the max distance to go back is back al the way to home. not necessairy but possible.
the min distance to go back would be the answer in question 2, but it asks for max distance.
so say home is at 184.3 and the trigger switches at 3.00. would this be 181.3? seems rather odd.
2) Z_probe_switching distance: [mm] = Max. distance to go back for next test.
i kinda understand this one. but the explanation and the name rather contradict themselves.
say the probe triggers at 3.00 mm and untriggers at 4.5mm would this be 1.5 or rather 4.5 (relative or absolute distance)
i guess i could take 4.5 but this gives an extra (unnecessary) move if only 1.5 is needed.
kind regards
Matthieu
but personally i thought that "Z_PROBE_BED_DISTANCE" ([mm] = Max. distance to go back for next test)
would make sure the spider wouldn't go all the way back up.. but if starting lower is the solution for that.. well easy enough.
as far as i'm aware i don't have any repetitions set.. if so where would i need to find that? is there a benefit is repetitions?
at the moment it measures three times. than goes all the way back up, comes down, measures 3 times goes back up and starts the 1 measure and crashes.
as it gets stuck after 6 smooth measures, everytime at the same point.. i believe i can discard option one. also you can hear the end stop switch click, so also option 2. unfortunately it crashes at the 7 test..without ever going back-up. so testing afterwards has no use. leaving all but option 3.
although i personally have my doubts about this.. but since i must admitt that the wires were, well at least less than neat arranged. i'll go for that untill disproven. i will fully rearrange the wires, make sure the endstop wires are twisted from the beginning (also i'm gonna upgrade the poor quality switches the printer came with) and get them as far away from the (extruder) motor wires as physically possible. pillar motors are at the bottom.. so not much interference there but also i will keep them away from each other as much as possible. also i will decrease the excess wire length at the bottom to get the neatest wire layout possible.
unfortunately i will need to crimp the jst plugs used. for this i ordered the correct crimps in china.. so this will take a few weeks before i get them. so i will be quite on this question because of that. doesn't mean it is solved (jet), just on temporary hold.
i didn't test m999 and m119.. as i already started to pull the wires when i remembered i still needed to do that, but i will do so if the issue remains after rewiring.
kind regards
Matthieu
