Auto Bed Leveling issue
I just installed a servo with a switch to have the autobed leveling feauture.It seems to work fine when the bed is almost level by adjusting the screws.But when its not that leveled when its trying to get to the last probe point the switch crashes into the bed causing the G32 to fail.The problem is that the Z axis doesnt raise too much after measuring each point to get to another one.Is there any option to tell the printer to raise the Z a good amount of mm in order to move to the next measuring point?.By the way i have set BED_LEVELING_METHOD 0.
Firmware version is 1.0 Dev
