Repetier-Server do not stop/start properly
Hi there,
I have just installe the actual version 0.50.2 of Repetier-Server on my Raspberry. Installation was really easy and on the first view it seems to run properly, including internet access and user management.
The server starts directly when I boot the raspberry.
But now I have found a problem, which I cannot solve.
When I get access to it from another machine with it's network address and port number 3344 everything is ok, the server keeps running and I can work with it.
But when I try to get access directly on the raspberry by using the preinstalled webbrowser and enter the network address like above or "localhost:3344" the server stops at once.
The answer from the command "/etc/init.d/RepetierServer status" is:
"[FAIL] Repetier-Server is not running".
How can I access to the Repetier-Server UI directly on the raspberry?
Hope anyone can help me
Cu
Klaus
Cu
Klaus
