Restart on dual extrusion
I'm just starting with dual extrusion on a reprap with a chimera hotend. I can print in either color/extruder on it's own just fine. But when I create a profile and slice a model for the left and another for the right (model is the trafic cone), around the 3rd layer or so when the right extruder starts, the machine restarts with the following error msg:
"WARNING: Device unplugged while connected to port
Disconnected."
Total build time: 5.06 minutes
Disconnected.
Disconnected."
. Any ideas what's going on? Running the latest repetier dev.
The chimera is 2 in 2 out. They just share a heatsink. Your think of the cyclops. That's 2 in 1 out. Aka a mixing extruder.
https://goo.gl/photos/H3BSdhNyatTeUiZw9
Config at https://1drv.ms/u/s!ApzOdVx9w7haifw1Tc8G1fmHvbuZ6Q
I tried. 92 and dev and same thing. This only happens with dual extrusion. I noticed one I tried with the layer fan turned off and it lasted a 3 min or so longer.
I originally had extruder 0 and 1 fan set to heater pin 3 (the fan on the heatsink not the layer fan). I set extruder fan 1 to disabled and same thing.
I also moved to a 30a PSU. And thing.
But not a fw issue.
