Printed models too small
Hi there, I use a 3d printer CTC (similar to Prusa I3), but all modesl are nearly 3,6% too small. How can I fix it without resizing models in stl-files? Is is possible to auto-resize slicing data? What can I do? May I change selected printer, because belts or leadscrews aren't the same as original Prusa i3?
But it sounds like you do not have the original configuration.h file. There are quite some parameters and it would be helpfull to have the old one as you only want to change the steps per mm setting and not figure out every hardware component again.
