Repetier Server Pass through for specialized software.
                    Hi.
I have a TEVO Black Widow running on an RPi with Repetier Server. All is working well and I can connect and work with my printer using Repetier Host.
Unfortunately I have added a Laser component to my printer and I need to control it using different software. This can connect using TelNet protocol.
Is there a way I can control my printer via Repetier Server acting in a 'pass through' capability?
Many thanks
Dave
Many thanks
Dave
I have found a utility called 'socat' and this will create a TCP/IP to USB connection on the PI side. Now I just have to ensure that I number my USB ports and tell Repetier Server only to use specific ports for the printer, and I can just plug the printer in to another port when I want to use 'direct' communication.
The port solution is good. Normally we use /dev/serial/by-id so that would not change by selecting different port, but there is also /dev/serial/by-path that changes just with the selected port so if you switch to that your problem is solved.
Can you explain how to set up by path
Many many thanks
Fining name sis as easy as plugin in one usb port and ls /dev/serial/by-path
you see the name for that case. Plugin on othe rusb repeat and you see a different name. Use these 2 names as port.
