Moving Manual Z in FW 1.0.3
Hi yesterday I made the upgrade to FW 1.0.3 from 0.92.9
The upgrade was beacause I need G33 working properly without Zmax switch so
I am using Zprobe like z min end stop mapped to z min switch.
I have read everything and this It´s working ok.
I have seen 3 problems that in versión 0,92.9 i haven.t.
1) Problem I run G32 S2 5x5 grid inside repetier host. In the middle of routine I press stop panic button (sorry I dont remember the true name). At this situation I can´t move Z axis to down only for Up. How can move manual the Z axis. I can´t homing beacause X axis is closed Z=150mm.
In versión 0,92,9 i can move Z axis in manual mode. I had to make a downgrade in order to move the Z axis and avoid the crash in this situation.
2) I want put and dialGauge in extruder. I need up Z axis but I can,t home i can move manual . In new versión this doesnt work
3) My method of calculate Z probe height is. Write in eprom Z probe height =0. Do homing al axis. G92 Z30 and manual going to down until NOzzle tip is 0,1mm from the bed. So z probe height = 30-down distance. This in 0.92.9 it´s working.
Surely is a problem of config, perhaps if I mark extruder is zprobe or Always_check_endstop the new versión Will work in manual mode as old.
The config.h was from 0.92.9 loaded in configuration tool 1.0.3. Only have added the trick for z-min endstop switch and z probe was the same and homing order explained in other threads.
Thanks in Advanced
| Detectar idiomaAfrikáansAlbanésAlemánAmháricoÁrabeArmenioAzeríBengalíBielorrusoBirmanoBosnioBúlgaroCamboyanoCanarésCatalánCebuanoChecoChichewaChino simpChino tradCincalésCoreanoCorsoCriollo haitianoCroataDanésEslovacoEslovenoEspañolEsperantoEstonioEuskeraFinlandésFrancésFrisioGaélico escocésGalésGallegoGeorgianoGriegoGujaratiHausaHawaianoHebreoHindiHmongHolandésHúngaroIgboIndonesioInglésIrlandésIslandésItalianoJaponésJavanésKazajoKirguísKurdoLaoLatínLetónLituanoLuxemburguésMacedonioMalayalamMalayoMalgacheMaltésMaoríMaratíMongolNepalíNoruegoPanyabíPastúnPersaPolacoPortuguésRumanoRusoSamoanoSerbioSesotoShonaSindhiSomalíSuajiliSuecoSundanésTagaloTailandésTamilTayikoTeluguTurcoUcranianoUrduUzbecoVietnamitaXhosaYidisYorubaZulú | AfrikáansAlbanésAlemánAmháricoÁrabeArmenioAzeríBengalíBielorrusoBirmanoBosnioBúlgaroCamboyanoCanarésCatalánCebuanoChecoChichewaChino simpChino tradCincalésCoreanoCorsoCriollo haitianoCroataDanésEslovacoEslovenoEspañolEsperantoEstonioEuskeraFinlandésFrancésFrisioGaélico escocésGalésGallegoGeorgianoGriegoGujaratiHausaHawaianoHebreoHindiHmongHolandésHúngaroIgboIndonesioInglésIrlandésIslandésItalianoJaponésJavanésKazajoKirguísKurdoLaoLatínLetónLituanoLuxemburguésMacedonioMalayalamMalayoMalgacheMaltésMaoríMaratíMongolNepalíNoruegoPanyabíPastúnPersaPolacoPortuguésRumanoRusoSamoanoSerbioSesotoShonaSindhiSomalíSuajiliSuecoSundanésTagaloTailandésTamilTayikoTeluguTurcoUcranianoUrduUzbecoVietnamitaXhosaYidisYorubaZulú |
G1 S1
would disable target position check.
2) G1 S1 as well.
3) Guess same as 1 and 2.
I run G92 Z30 after G1 S1 and the FW worked like 0.92.9. I can down the z axis suppose the same apply to x axis and y.
Where is target position check via web configuration? or is possible via G1 S1 command only
Thanks a lot of this behavour was making crazy
Another question I tried 1.0.4 develop in order to resolve the earlier trouble when I have compiled version show a message of "Low memory disponibility" so is there any part of FW i can remove in order to avoid the message,
I have not display so I cant remove languajes.
Thanks a lot of for your FW and support
If you have no display ignore the message. Test seems not to check that case. If you select a display you could remove languages to stop the message and then disable display again.
