Multiple Event Driven @Execute commands
Hi Guys. I have commands set up for each of my printers to send a push notification via pushbullet, wait for 10 minutes and turn off the Sonoff Basic powering the printer. These have been working perfectly. Because I am now printing Covid face shields practically 24/7 I have separated the command files and added extra lines to the extcommands.xml so there is a command for the notification and a separate one for turning off the Sonoff. So, in the 'Run After Job' event driven area, I have 2 lines, one for the notification, the other for the power off:
It was my intention to comment out the power off during the day and uncomment when I set the last print of the day and go to bed.
The issue I have is that the second command never runs. I've tested them both individually and they work fine. Is it the case that you can only have one @execute line for event driven gcode or am I stupidly missing something?
John
@execute e3rdone
@execute e3rdelayoffIt was my intention to comment out the power off during the day and uncomment when I set the last print of the day and go to bed.
John
PS: In next release there is new event shutdown after print and you can activate to run shutdown script in the printer menu. So no modifications needed any more then.
Line in extcommands is:
<execute name="e3delayoff" allowParams="false">bash /home/pi/scripts/e3delayoff.sh</execute>
The corresponding e3delayoff.sh code is:
Nice to hear about the addition to the next release :-)
exit 0
so it never returns an error code. Bur they should be started asynchroneously anyway so they run in parallel.
