error starting monitor
on ubuntu focal
--- begin
cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=20.04
DISTRIB_CODENAME=focal
DISTRIB_DESCRIPTION="Ubuntu 20.04.1 LTS"
--- end
DISTRIB_ID=Ubuntu
--- end
the start of the host program
--- begin
ls -l /Daten/L/3D-Printing/Repetier-Server\ Monitor-1.3.0.AppImage
-rwxrwxr-x 1 root users 89884952 Feb 4 15:20 '/Daten/L/3D-Printing/Repetier-Server Monitor-1.3.0.AppImage'
--- end
--- end
via AppImage creates an errror:
--- begin
app starting... /tmp/.mount_Repeti701j5y/resources/app.asar/background.js
Is master: true
App user data path:/home/piet/.config/Repetier-Server-Monitor
upload start master true
background loaded
(node:16576) ProtocolDeprecateCallback: The callback argument of protocol module APIs is no longer needed.
bg closed
--- end
Is master: true
background loaded
bg closed
--- end
and stops. Other AppImages like e.g. prusa-sclicer work without interruption.
Whats wrong here?
Thank You for Your attention
regards
jori
Question is also did you ever see it appearing or trying to appear?
If it ever worked the settings might be corrupted. Try deleting or reaming ~/.config/Repetier-Server-Monitor and then start again. Then it starts with fresh initialization.
