How to setup an ESP8266 Wifi Module on Repetier Firmware?
I recentky bought an ESP8266 -01 wifi module, flashed it with a transparent tcp-serial bridge and wired it up to the AUX-1 on the RAMPS (D1 D0). It was working very well on the Marlin firmware with only a change of BaudRate to 115200. I used the following firmwar eon the ESP module http://www.roboremo.com/esp8266-tcp-to-serial.html.
But when I switched to Repetier Firmware (0.92), it doesn't work with just a baudrate change. What else should I do??
Thank you
